While training: KeyError: 'test_lossESR_final
Picking up modeling amps from digital blends again.
Getting the KeyError: ‘test_lossESR_final’ error when I try to do the training step while training a model. This is not the first time I create a model but it’s the first time I’m stuck in this step. It’s been a while since I created my last model though.
Filesizes of input and target check out, so does the rate.
I fail to dirive the cause from the coude output :confused:
/content/Automated-GuitarAmpModelling/CoreAudioML/networks.py:28: FutureWarning: `torch.cuda.amp.custom_fwd(args...)` is deprecated. Please use `torch.amp.custom_fwd(args..., device_type='cuda')` instead.
  def forward(ctx, input, min, max):
/content/Automated-GuitarAmpModelling/CoreAudioML/networks.py:33: FutureWarning: `torch.cuda.amp.custom_bwd(args...)` is deprecated. Please use `torch.amp.custom_bwd(args..., device_type='cuda')` instead.
  def backward(ctx, grad_output):
args.model = SimpleRNN
args.device = MOD-DWARF
args.file_name = PF-SpacePirate
args.input_size = 1
args.hidden_size = 16
args.unit_type = LSTM
args.loss_fcns = {'ESR': 0.75, 'DC': 0.25}
args.skip_con = 0
args.pre_filt = A-Weighting
existing model file found, loading network.. continuing training..
/usr/local/lib/python3.10/dist-packages/torch/__init__.py:955: UserWarning: torch.set_default_tensor_type() is deprecated as of PyTorch 2.1, please use torch.set_default_dtype() and torch.set_default_device() as alternatives. (Triggered internally at ../torch/csrc/tensor/python_tensor.cpp:432.)
  _C._set_default_tensor_type(t)
/usr/local/lib/python3.10/dist-packages/torch/optim/lr_scheduler.py:60: UserWarning: The verbose parameter is deprecated. Please use get_last_lr() to access the learning rate.
  warnings.warn(
  0% 1/540 [00:03<34:53,  3.88s/it]
Traceback (most recent call last):
  File "/content/Automated-GuitarAmpModelling/dist_model_recnet.py", line 238, in <module>
    val_output, val_loss = network.process_data(dataset.subsets['val'].data['input'][0],
  File "/content/Automated-GuitarAmpModelling/CoreAudioML/networks.py", line 777, in process_data
    output[l * chunk:(l + 1) * chunk] = self(input_data[l * chunk:(l + 1) * chunk])
  File "/usr/local/lib/python3.10/dist-packages/torch/nn/modules/module.py", line 1553, in _wrapped_call_impl
    return self._call_impl(*args, **kwargs)
  File "/usr/local/lib/python3.10/dist-packages/torch/nn/modules/module.py", line 1562, in _call_impl
    return forward_call(*args, **kwargs)
  File "/content/Automated-GuitarAmpModelling/CoreAudioML/networks.py", line 698, in forward
    x, self.hidden = self.rec(x, self.hidden)
  File "/usr/local/lib/python3.10/dist-packages/torch/nn/modules/rnn.py", line 917, in forward
    result = _VF.lstm(input, hx, self._flat_weights, self.bias, self.num_layers,
RuntimeError: cuDNN error: CUDNN_STATUS_NOT_SUPPORTED. This error may appear if you passed in a non-contiguous input.
KeyError                                  Traceback (most recent call last)
<ipython-input-6-6e2df7b97e5b> in <cell line: 46>()
     44 model_dir = f"/content/Automated-GuitarAmpModelling/Results/{file_name}_{config_file}-{skip_con}"
     45 step = max(step, 2)
---> 46 print("Training done!\nESR after training: ", extract_best_esr_model(model_dir)[1])
/content/Automated-GuitarAmpModelling/colab_functions.py in extract_best_esr_model(dirpath)
    161   with open(stats_file) as json_file:
    162     stats_data = json.load(json_file)
--> 163     test_lossESR_final = stats_data['test_lossESR_final']
    164     test_lossESR_best = stats_data['test_lossESR_best']
    165     esr = min(test_lossESR_final, test_lossESR_best)
KeyError: 'test_lossESR_final'
The google colab page which the MODAudio/AIDA DSP crew set up for model training has been neglected for a long time. Maybe they’ll get around to updating & fixing it some day or maybe it will continue to be left alone. It all depends on whatever business situation the company is in (which I do not know of) at the moment. Perhaps the team might tell us more.
Ah, …
This process is the core of user generated content when it comes to profile tech.
Hope the program still has future :confused:
Hey @LievenDV,
I wrote about it in this thread. We still intent to fix it but it will take time.
Hi there,
I’m experiencing the same problem as LievenDV.
Here is the error code:
args.file_name = Normal
args.input_size = 1
args.skip_con = 1
no saved model found, creating new network
  warnings.warn(
  0% 1/200 [00:02<09:38,  2.91s/it]
  File "/content/Automated-GuitarAmpModelling/CoreAudioML/networks.py", line 691, in forward
<ipython-input-4-c34516351da8> in <cell line: 46>()
I hope the project is not dead, because AIDA is really a nice plugin.
Bye
Some temporary fixes have been made on the aidadsp_devel branch.
When running STEP 0 you’ll be ask to restart the session. DON’T !
Edit the code of Step five.
Find the line : shutil.copyfile(os.path.join(model_dir, ‘model_keras.json’), os.path.join(‘/content’, os.path.split(model_dir)[-1]+‘.aidax’))\
Replace .aidax with .json. Or if you’re not confortable with messing with the code, download manually the model file in the content folder.
Don’t run step 4 as it may crash the whole session.
Optionnaly at step 2, I usually change “norm=True” to “norm=False”.
thanks for the heads up, missed that line.
Should be fixed now for step 5.
Ok, Tried again;
had to “restart session” because some updates but third time worked like a charm.
Need to test the model itself but it’s a high gain amp model that landed on an 0.018 ESR so that should be promising enough.
Thanks all involved! :heart:
Having this error again today
@spunktsch same type of issue or is it me? ^^
Code/error dump:
/content/Automated-GuitarAmpModelling/CoreAudioML/networks.py:27: FutureWarning: `torch.cuda.amp.custom_fwd(args...)` is deprecated. Please use `torch.amp.custom_fwd(args..., device_type='cuda')` instead.
  @custom_fwd
/content/Automated-GuitarAmpModelling/CoreAudioML/networks.py:32: FutureWarning: `torch.cuda.amp.custom_bwd(args...)` is deprecated. Please use `torch.amp.custom_bwd(args..., device_type='cuda')` instead.
  @custom_bwd
WARNING: All log messages before absl::InitializeLog() is called are written to STDERR
E0000 00:00:1743264274.702080    2302 cuda_dnn.cc:8310] Unable to register cuDNN factory: Attempting to register factory for plugin cuDNN when one has already been registered
E0000 00:00:1743264274.708400    2302 cuda_blas.cc:1418] Unable to register cuBLAS factory: Attempting to register factory for plugin cuBLAS when one has already been registered
args.file_name = Trivium lead
args.input_size = 1
args.skip_con = 0
/usr/local/lib/python3.11/dist-packages/torch/__init__.py:1236: UserWarning: torch.set_default_tensor_type() is deprecated as of PyTorch 2.1, please use torch.set_default_dtype() and torch.set_default_device() as alternatives. (Triggered internally at /pytorch/torch/csrc/tensor/python_tensor.cpp:434.)
/usr/local/lib/python3.11/dist-packages/torch/optim/lr_scheduler.py:62: UserWarning: The verbose parameter is deprecated. Please use get_last_lr() to access the learning rate.
  warnings.warn(
  0% 1/400 [00:03<22:55,  3.45s/it]
  File "/usr/local/lib/python3.11/dist-packages/torch/nn/modules/module.py", line 1739, in _wrapped_call_impl
  File "/usr/local/lib/python3.11/dist-packages/torch/nn/modules/module.py", line 1750, in _call_impl
  File "/usr/local/lib/python3.11/dist-packages/torch/nn/modules/rnn.py", line 1124, in forward
    result = _VF.lstm(
<ipython-input-4-b5bcbd2cac6e> in <cell line: 0>()
