I have looked through the forum and official docs, but haven’t come across any detailed instructions. Forgive me if I overlooked the obvious.
I ordered Type A dongles/adapters (1/4 trs to MIDI Din), but I can’t seem to get the dwarf to change presets.
I set it to receive on channel 15, and my MIDI controller is sending on channel 15, but nothing works.
I tried adding bank change values, too. No result.
I’ve tried changing cables (my Zoia uses the same type of dongle), and changing MIDI channels, but no luck.
My other gear all responds to PC messages from the same MIDI controller.
I have also taken all the other gear out of the MIDI chain, in case something else wasn’t passing messages or channels thru.
Any ideas?
(P.S. Very much enjoying the sounds I’ve coaxed out of the Dwarf, and am now trying to incorporate it into my board. Thanks MOD!!!)
