I tend to max out the parameter mappings, which gets pretty confusing and unclear, because the map only shows which slot is used, but not by which parameter. That makes keeping an overview difficult, and it is tedious to go back and find that one parameter to switch off or change positions, for instance.
It would alredy help if the parameter names would show. It would be even better if the module name could show too.
To put the icing on the cake, a list print-out button would help a lot to memorize complex patches.
