Wavetable Synth
Hey mod team
Any chance of getting this free LV2 wavetable synth ported to the dwarf ?
The number of synths on the dwarf is limited as it is but this would greatly add to it!! It’s sounds great and is very powerful.
Jarryd
Hmm, I believe that synth is quite heavy even on a desktop. So I don’t think it will be very performant on the Dwarf. (might be due to the UI though)
Next to that it would require some significant work for a functional UI, considering the number of controls that it has it would be very difficult to use without any UI.
In theory it could be ported of course, but would the amount of work required outweigh the results?
Did you check out the WT module from Surge with Cardinal? You should be able to load your own WT`s there.
