Just a note in case it has been tested sufficiently and can be implemented on ModAudio.
A dream come true: The legendary Sherman Filterbank - Linux build (untested - Linux users, please test it!) - as a plugin from verstaerker \o/
==> https://github.com/verstaerkermusic/vorm-fb01
vørm fb01
Analog filtering. Powerful saturation. Hands-on control.
vørm fb01 is an audio effect by verstaerker that authentically models an analog dual filter with powerful saturation. Developed through extensive measurements and direct listening comparisons, its sound model captures the interaction of input drive, resonance and modulation.
Shape drums, synths and textures with subtle movement, resonant sweeps or intense distortion.
Features
Two continuously blendable Multimode Filters with parallel/serial routing and an adjustable Out1/Main mix.
Nonlinear input drive, saturation and signal-dependent resonance.
FM and AM with internal sources and external sidechain inputs.
ADSR, AR and Envelope Follower with audio and MIDI triggering.
LFO modulation from slow movement into audio rate, plus Harmonics sync.
Optional character controls: noise, hum, FM bleed and Out1 asymmetry.
Preset browser, A/B comparison, custom Init settings and MIDI Learn with controller profiles.
Gain Match, Wet Level, output limiter/clipper, stereo-width control and selectable processing quality up to 384 kHz.
Linked knob pairs: Cmd-drag on macOS or Ctrl-drag on Windows, preserving their relative offset.
Platforms
macOS 12+: Apple Silicon and Intel; AU, VST3 and CLAP.
Windows 10/11 x64: VST3 and CLAP.
Linux x86_64 beta: VST3, LV2 and CLAP; built on Ubuntu 22.04, X11 editor. Other distributions and real DAW setups need testing.
Host sample rates from 32 to 192 kHz, including 44.1 and 48 kHz.
English and German interface and guides.
