Hi all, I am looking how i can use the dwarf to create a robot effect while using a microphone with the dwarf. Does anyone has an idea to manage this?
Greetings
Detlef
Greetings
Detlef
There’s an autotune plugin that would do that if set right, a la Cher
Hi ,
With this:
(there are others, the calf Ringmodulator being the best in my opinion)
And this:
You should be able to do a lot of things already.
Hi @Detgyver,
What usually crates a robotic voice in popular tunes (e.g. : Daft Punk’s Harder, Better, Faster, Stronger) is an effect called vocoder. Maybe you can try this plugin :
Thanks for your tipps, I will check out and give it a try!
Greetings
Detlef
For a robot-like voice, you need a vocoder, as @funkypou indicated above, plus a wave generator. The BLOP generators are great for that.
Here is a board for you: Robot voice - MOD Audio
