I think the title says it: The amp has CV enabled for on/off, for Bright and for Boost but it is absent for the clean/Lead channel select. Any chance of adding it?
I’m not sure why it is not. But I mapped the request.
Great
Probably just an oversight.
In my experience, CV doesn’t work with controls that present a list. In this case, even though the Titan’s channels are represented with a switch, the control is actually selecting between a 2-item list. I had the same issue with the 1-2 and 2-1 switches. I wanted to use CV to move the switch position, but cannot.
I could probably use Mindi to make the selection based upon CV, might have a look at that later tonight.
