Description
When a bi-polar value is assigned to a device poti, the maximum value wraps to 0 under certain conditions.
How to reproduce
- Create stereo fade plugin
 - Assign the fader to a poti on the device
 - Set the target range to -0.3 and 1.0
 - Turn the poti until it reaches 1.0
 - See that the value jumps to 0 instead
Expected/suggested solution
1.0 is reached so that only B can be heard.
Additional information
Unit:  MOD Duo X
Build Date:  2020 Jul 26 06:33:32
OS Version:  1.9.1.1455
