…but not switches on the footswitch extension, it seems.
MOD 1.5.0.423
footswitch 0.0.6
MOD 1.5.0.423
footswitch 0.0.6
Correct, the control chain footswitch does not have tap-tempo mode implemented yet.
(it’s a per-device function)
ok, thanks… good to know!
build 425 is here:
both are regressions in 1.4 series. the next 1.4 RC / final release will have them too.
425 is looking good over here, running a couple of pedalboards with the control chain footswitch and an external MIDI controller included!
There is actually something (probably simple), that I would like to have an option on for the “settings” page: Double clicking a pedal: Zoom in (current behaviour) or open the plugin’s details. Does that make sense? … or am I the only one using double clicks in a web context?
it’s a single click to zoom-in a pedal/plugin, not double click.
I think the only double-click used on the web interface is for zooming out the canvas (double-clicking an empty area)
Build 440 is here:
This build has all the fixes that are coming to 1.4-RC6, to be released tomorrow.
Build 449 is here:
Control Chain stuff was broken in the last build, we forgot a few things…
But it should be working perfectly now.
An update of the footswitch firmware is coming too, to complement the changes.
Build 456 is here.
This has all the fixes regarding control chain that are going to the upcoming v1.4.1 stable release.
Plus system tweaks to make the system boot a bit faster.
Build 461 is here.
Includes the DIN-MIDI fix that will be part of v1.4.1.
Build 477 is here.
Imported fixes from v1.4.2:
The tuner isn’t working currently on mine, all I ever see is the default “?”. I’ve tried switching the instrument cable from Input 1 to 2 and have rebooted a few times with different pedalboards as the default. When I access the tuner screen, the input light registers when I strike guitar strings but the display never updates from the “?” regardless of which input I’ve selected.
1.5.0.477
Build 481 is here.
we changed to way the system and user data partitions are mounted.
‘sync’ and ‘commit=1’ options were removed from user data mount options.
instead, it now uses ‘nodelalloc’. mod-ui code was tweaked to make it flush/fsync after writing a file to disk, before returning a “finished” reply to the browser.
the system partition now also has ‘nodelalloc’, as some of you/us mount the system partition as RW sometimes…
I did quite a few tests with these mount options, I’m confident it makes the system a little more robust.
But in case something goes wrong, this wiki page will be of help http://wiki.moddevices.com/wiki/Troubleshooting_Reinstall
(having ‘nodelalloc’ and mod-ui calling flush+fsync should ensure files are really written to disk. Also, when possible, we save to a temporary file first, flush to disk, and then rename the file.)
Oh, I completely forgot, but 3 new plugins were added to stable for those running v1.5.
“Metronome”, “MIDI TImecode” and “MIDI Clock”.
Metronome is obvious, this new plugin has the sound synced with the MOD transport state (contrary to CAPS metronome).
MIDI Timecode and MIDI Clock will generate a MIDI signal based on the transport state, so you can drive external gear with the MOD Duo.
The other way around is not supported yet (ie, MOD as slave / MTC or MIDI Clock for managing MOD transport)
Build 490 is here.
Brings the fixes from v1.4.3, specifically:
A few notes from recent testing:
I was having trouble finding the new MIDI plugins in the store - a refresh and an Update All got them showing up. After installing MIDI Timecode and MIDI Clock, I went to add them to the pedalboard but was also having trouble finding them there in their respective categories and ended up plucking them from “All” instead. Sorry this isn’t steps to replicate - I’ll pay closer attention next time to my individual steps and the state of the UI.
I added the MIDI Clock to a pedalboard and am successfully using to drive the arpeggiator tempo on an Akai MPK Mini - fantastic!
Oh one other minor annoyance, the BPM popup window only seems to close when you click on the menu again - a close button and/or non-focused click to close would be handy
Keep up the great work!
build 498 is here!
first, 2 small things in the web interface:
The way JACK starts has changed. Instead of having different services for the internal clients (mod-host, peakmeter, ttymidi), the clients are loaded at the moment that jackd starts.
This reduces the number of systemd services during boot, and also makes it easier to debug JACK stuff.
ie, just stop jack2 service and run mod-jackd to get the entire setup running.
And finally, a new feature was silently added. MOD-SDK can now run inside the MOD!
(MOD-SDK is not the best name for the tool… but it’s something for creating modguis using a wizard, previewing them, and deploying to a MOD. When running inside the MOD Duo, the deploy section is hidden, for obvious reasons ;))
This is quite handy if you want to quickly modify an existing modgui style, or create a new one. No more excuses for having tuna-cans on the pedalboard assembler screen!
If you mess up, just remove and install the plugin again.
Some small notes:
MOD-SDK comes disabled by default.
Open the settings page, advanced section and enable mod-sdk service.
Then you can open http://modduo.local/sdk which redirects to the correct page.
For the curious ones, here’s how the wizard looks like:
Hi @falkTX,
I just tried to download and the progress bar starts to show the download. At 100% I got “Download failed!”. I tried again - same error. I also booted up the Duo: won’t help.
Currently I have 1.5.0.490 running and I am using Firefox/Linux. I also tried Chrome on Linux and Firefox/Chrome on Windows with the same results.
Regards, Holger
