Hi Mod Devices team,
being new here, first I would like to send out big thanks for this great product!
So far I am playing around with running mod-host and mod-ui on my Raspberry PI. In order to be able to change some settings quickly, I was trying to use the API provided through https://github.com/moddevices/mod-ui/blob/master/mod/webserver.py. However I could not find much documentation and few examples, so it is mostly try and error and reading the code to get something working.
What I e.g. have working:
Via curl -F 'bundlepath=/var/modep/pedalboards/MyOne.pedalboard' http://192.168.86.46/pedalboard/load_bundle/ I can load an existing pedalboard.
Via curl http://192.168.86.46/snapshot/load?id=1 I can load a specific snapshot of a pedalboard.
Via curl http://192.168.86.46/pedalboard/current I get the currently loaded pedalboard
Via curl http://192.168.86.46/pedalboard/info/?bundlepath=/var/modep/pedalboards/MyOne.pedalboard I can get info about a specific pedalboard, like the instance name of an effect/plugin.
What I did not get working:
While I can get info about a specific pedalboard via
http://192.168.86.46/pedalboard/info, how can I read the state of the current pedalboard, which might have unsaved changes? -
How can I set the parameter of an effect/plugin within the loaded pedalboard?
I looked at the implementation for/effect/parameter/set/?here: https://github.com/moddevices/mod-ui/blob/master/mod/webserver.py#L1020. Seems like it is reading the body of the sent request and splits it intosymbol, instance, portsymbol, valuewhere later onlyinstance, portsymbol, valueare used.
Thus I tried e.g.curl -X POST http://192.168.86.46/effect/parameter/set/? -H "Content-Type: application/json" -d 'unused/Gain/Gain/0.5'for a pedalboard with this content (cut after the Gain plugin):
"title":"MyOne",
"width":1960,
"height":3220,
"midi_separated_mode":false,
"plugins":[
"valid":true,
"bypassed":false,
"instance":"Gain",
"uri":"http://moddevices.com/plugins/mod-devel/Gain",
"bypassCC":{
"channel":-1,
"control":0,
"hasRanges":false,
"minimum":0.0,
"maximum":1.0
"x":36.0,
"y":20.0,
"ports":[
"valid":true,
"symbol":"Gain",
"value":0.0,
"midiCC":{
"channel":-1,
"control":0,
"hasRanges":false,
"minimum":0.0,
"maximum":1.0
"preset":""
Any help is very much appreciated!
Cheers,
Thomas
