Is there a way to use GUI without connecting MOD Duo X?
It would be very usefull since creating a pedalboard is very time consuming and I have a lot of time when I could do it but not so many time when I can connect MOD (fo e.g. at work…
I know this: https://sandbox.moddevices.com/, but now is apparently for test purposes.
Thank you so much!!
Can you download your own presets in the sandbox and then save them on your own mod device?
In general, I like the idea of creating presets on your own $computer, independent of the mod device, and then saving them to the mod device. To create basic ideas of effect wiring (effect blocks (*1)).
Also I would like to be able to create certain arrangements of effects and connections directly on the device.
(*1) Effect blocks:
You can select a range within a preset and move/delete/… in the GUI and/or save it separately as a new effect block. Within a preset you can then load individual effect blocks into the existing preset.
Do you know when it is possible to use it - I 've managed to use it once, everytime servers are full…
Sometimes they were full. I suspect that it occurs in two cases:
- They services really are full. So, there aren’t resources disposable now for dispose a instance for now;
- The server is in maintenance.
Who know what are occurring is @falkTX (I think)
There seems to be a bug where some instances are not cleared properly and thus never free to use again.
I have just restarted them now
It seems it worked yesterday but today again all servers are full all the time.
can you reset sandbox, it does not work
Is there a way to change the tempo of midi tracks? I tried to change global tempo and it does not change the speed of a track - it would be nice to make them slower
A question slightly out of topic here - for this type of case/question feel free to create a new thread, just keeps things easier to find for others and even for you
Are you using the MIDI File plugin? If yes, do you have the Host Sync turned on?
Yes, you are right, it might be a general case.
Yes, host sync is turned on (I use Midi file), but if I change global tempo (set to Internal) it does not affect the tempo at all. I test it on sandbox.
hmm ok. Maybe this is a bug, but on the sandbox. Are you using try.moddevices.com?
no, it is just how it works. the midi file player plays songs as-is, it does not ever change tempo
I’ve tried here:
https://sandbox.moddevices.com/session-timedout
But I’ve just tried on try.moddevices.com and it does not work too.
I use it through mozilla and chrome.
@falkTX just answered you (I guess you both posted simultaneously)
Just thought I’d reference this thread ![]()
still seems to be dead for me :S
