Hi all…is there any way to convert the audio from the guitar into a signal to trigger any of the midi input plugins? Im guessing not, as its not being talked about .![]()
The simplest way to do that is to use the Cardinal Mini plugin :
Keep in mind that the result is far from perfect, as it’s often the case in audio to MIDI conversion.
