User preset - assign button
Hi guys, how to assign the foot button for ONLY rotate the “user” preset? cause the button rotate all the presets (factory + user). (see the photo)
ifound a bug, the switch of sound work only if i choose the button of the main device pedal MOD DUO (1 or 2) if i choose the buttons of the footswith don’t work…
update, if i connect only one footswitch and assign the command to button 3 of the foot switch it work.. if i connect the two footswitch "in serie"and assign the command to button 3 of the first footswitch don’t work… someone can help me? maybe i have to reset bolt the footswitch?
(in the photo one in connected and one no)
Do you mean that the footswitch doesn’t work at all?
Have you tried to boot the MOD Duo only with one footswitch and then connect the other?
no i never try, so you suggest me to switch on the mod duo with one foot pedal connected and after connect the second one without switch off the main Mod duo? isn’t dangerous?
the function “assign all” (see the photo above) work good in footswitch 1&2 of moduo and footswitch(1,2,3,4) of pedal 1, but if i connect the second pedal to the first one (in serie) that function work only on modduo footswitch… it’s like the two pedal connected create a bug… someone can help me?
Sorry for the late reply here @Gabry_Stick
Yes.
no :slight_smile:
I’m not really sure if I understood this part.
After connecting the second footswitch have you tried to refresh the WebGUI? Would that solve your issue?
thank for your replay, how can i do it??
Simply refresh the browser page.
I’m wondering if that’s not a problem on the listing that once you refresh the WebGUI page is already updated.
It’s a bit of a wild guess, but I guess worth to try out.
