Im using my mod duo x with different devices here in my home studio and Im trying to figure out the best solution with cable management etc.
Right now I have my Mod Duo X connected to a USB hub where I connect my synths, and then I have a cable from my Mod Duo X into my iMac for using the web-interface.
Are there any way that I can connect my iPad to the USB hub also to send/receive midi from that as well?
Ealier Ive used my Ipad with the USB hub and then used a midi din cable->USB for connecting the duo x to the usb hub, but I dont always use my iPad in the setup, and its nice to always have my synths connected to the duo x…
Another thing, I can see its possible to connect the duo x with a bluetooth dongle to use the web-interface, but then its using the only usb slot that are also used for connecting synths.
Is it possible to connect the bluetooth dongle to the usb hub or am I missing something?
Sorry for my long and complicated message, I hope that you can make some sense out of it, and can help me out
Have a nice evening
Just to be completely sure, before I will order a bluetooth dongle. Your reply is to that it is possible to connect the bluetooth dongle to the USB Hub, right?
I personally used an Arturia MIDI controller, a 12 Step from McMillen and the Bluetooth dongle all connected to a USB hub that is connected to my ModDuo.
