USB and FEL boot doesn't work anymore. EDIT : Now doesn't boot at all
Description
A. The USB-A input doesn’t work anymore (tested with a bluetooth dongle and a USB key (backup menu say that there is no key connected, and bluetooth menu statut is “Unavailable”).
B. The mod is stuck on boot screen when trying to boot while pressing the FEL button, here is the result of the “./bootfix -w modduo-latest-reset-image.raw” command on linux:
Blockquote
Speed = 12 Mbps
Start stage 1
URB 5
AWUSBFEX soc=001651 (A20) fw=01 mode=fel type=D len=08 addr=7e00
Detected A20 (ID 0x1651)
URB 14
URB 23
URB 32
URB 41
URB 50
URB 63
URB 72
URB 77
Sending sun7i/fes_1-1.fex…done
URB 87
URB 96
URB 105
URB 114
Sending sun7i/fes_1-2.fex…done
URB 120
URB 129
URB 138
1024MB RAM detected
URB 147
URB 153
URB 165
URB 174
Sending sun7i/fes.fex…done
URB 192
Sending sun7i/fes_2.fex…done
URB 198
End of stage 1
Re-opening…done
Speed = 480 Mbps
Start stage 2
URB 5
AWUSBFEX soc=001610 (fes) fw=01 mode=fes type=D len=08 addr=7e00
URB 14
URB 24
URB 32
URB 42
URB 51
URB 60
Sending sun7i/magic_de_start.fex…done
URB 69
Sending sun7i/fed_nand.axf…done
URB 123
Sending sun7i/magic_de_end.fex…done
URB 132
URB 135
URB 140
..Wait..done
URB 150
URB 153
Max NAND key = 15466496
Failed to open file to send: : No such file or directory
How to reproduce
A
  1. Connect an USB device
  2. See it’s not detected nor powered
B
1 Click and hold down the FEL button on the back of the MOD Duo (in tiny hole), while you power it on.
2 Hold it for 2 seconds, then release
Expected/suggested solution
USB device should be detected, the FEL reboot should works.
  • Operating system: Linux
  • System version: Manjaro (latest)
NB : if the device information section is missing in my first post it’s because that the mod doesn’t boot anymore even in normal boot mode :confused: (this 3rd bug occurred while I was writing the post)
cant say much about problem #1 without more info, but regarding the factory reset, I think you are just missing the full path to the file in question. We can see it from this:
maybe it needs ./ before the filename, I am not sure now.
yep you where right, the correct syntax was dot dot slash since the .raw is in the parent folder…
So I’m now proceeding to the factory reset, I’ve got the blue light and then the red light so I guess it’ll fine.
Dunno if it will fix the USB bug or if it’s an hardware problem, will let you know once its finished.
Ok I just finnished with the factory reset.
But the USB-A still doesn’t work.
Here are more infos:
version : 1.6.1
restore : b221042
system : 1a51cf6
controller : a5fa955
