I used Google Colab to train models for AIDA-X in the past, but today I encountered errors in the 0.DEPS section. After displaying the errors, Colab prompts me to restart the runtime. However, even after restarting, the same issue persists. If I skip this section, all subsequent steps also result in errors. Do you know if this is a temporary issue? Iβll share the 0.DEPS messages below
"WARNING: Your environment has PyTorch 2.0.1+cu117 and CUDA 11.7. This environment is not supported.
Proceeding to install required dependenciesβ¦
Found existing installation: torch 2.0.1+cu117
Uninstalling torch-2.0.1+cu117:
Successfully uninstalled torch-2.0.1+cu117
Found existing installation: torchvision 0.15.2+cu117
Uninstalling torchvision-0.15.2+cu117:
Successfully uninstalled torchvision-0.15.2+cu117
Found existing installation: torchaudio 2.0.2+cu117
Uninstalling torchaudio-2.0.2+cu117:
Successfully uninstalled torchaudio-2.0.2+cu117
WARNING: Skipping tensorflow as it is not installed.
WARNING: Skipping tensorboard as it is not installed.
Looking in links: https://download.pytorch.org/whl/torch_stable.html
Collecting torch==2.0.1+cu117
Downloading https://download.pytorch.org/whl/cu117/torch-2.0.1%2Bcu117-cp311-cp311-linux_x86_64.whl (1843.9 MB)
ββββββββββββββββββββββββββββββββββββββββ 1.8/1.8 GB 223.4 MB/s eta 0:00:00
Collecting torchvision==0.15.2+cu117
Downloading https://download.pytorch.org/whl/cu117/torchvision-0.15.2%2Bcu117-cp311-cp311-linux_x86_64.whl (6.1 MB)
ββββββββββββββββββββββββββββββββββββββββ 6.1/6.1 MB 159.4 MB/s eta 0:00:00
Collecting torchaudio==2.0.2+cu117
Downloading https://download.pytorch.org/whl/cu117/torchaudio-2.0.2%2Bcu117-cp311-cp311-linux_x86_64.whl (4.4 MB)
ββββββββββββββββββββββββββββββββββββββββ 4.4/4.4 MB 164.4 MB/s eta 0:00:00
Requirement already satisfied: filelock in /usr/local/lib/python3.11/dist-packages (from torch==2.0.1+cu117) (3.18.0)
Requirement already satisfied: typing-extensions in /usr/local/lib/python3.11/dist-packages (from torch==2.0.1+cu117) (4.12.2)
Requirement already satisfied: sympy in /usr/local/lib/python3.11/dist-packages (from torch==2.0.1+cu117) (1.13.1)
Requirement already satisfied: networkx in /usr/local/lib/python3.11/dist-packages (from torch==2.0.1+cu117) (3.4.2)
Requirement already satisfied: jinja2 in /usr/local/lib/python3.11/dist-packages (from torch==2.0.1+cu117) (3.1.6)
Requirement already satisfied: triton==2.0.0 in /usr/local/lib/python3.11/dist-packages (from torch==2.0.1+cu117) (2.0.0)
Requirement already satisfied: numpy in /usr/local/lib/python3.11/dist-packages (from torchvision==0.15.2+cu117) (2.0.2)
Requirement already satisfied: requests in /usr/local/lib/python3.11/dist-packages (from torchvision==0.15.2+cu117) (2.32.3)
Requirement already satisfied: pillow!=8.3.*,>=5.3.0 in /usr/local/lib/python3.11/dist-packages (from torchvision==0.15.2+cu117) (11.1.0)
Requirement already satisfied: cmake in /usr/local/lib/python3.11/dist-packages (from triton==2.0.0->torch==2.0.1+cu117) (3.31.6)
Requirement already satisfied: lit in /usr/local/lib/python3.11/dist-packages (from triton==2.0.0->torch==2.0.1+cu117) (18.1.8)
Requirement already satisfied: MarkupSafe>=2.0 in /usr/local/lib/python3.11/dist-packages (from jinja2->torch==2.0.1+cu117) (3.0.2)
Requirement already satisfied: charset-normalizer<4,>=2 in /usr/local/lib/python3.11/dist-packages (from requests->torchvision==0.15.2+cu117) (3.4.1)
Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.11/dist-packages (from requests->torchvision==0.15.2+cu117) (3.10)
Requirement already satisfied: urllib3<3,>=1.21.1 in /usr/local/lib/python3.11/dist-packages (from requests->torchvision==0.15.2+cu117) (2.3.0)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.11/dist-packages (from requests->torchvision==0.15.2+cu117) (2025.1.31)
Requirement already satisfied: mpmath<1.4,>=1.1.0 in /usr/local/lib/python3.11/dist-packages (from sympy->torch==2.0.1+cu117) (1.3.0)
Installing collected packages: torch, torchvision, torchaudio
Successfully installed torch-2.0.1+cu117 torchaudio-2.0.2+cu117 torchvision-0.15.2+cu117
WARNING: The following packages were previously imported in this runtime:
[nvfuser,torch]
You must restart the runtime in order to use newly installed versions.
ERROR: Could not find a version that satisfies the requirement tensorflow==2.11.0 (from versions: 2.12.0rc0, 2.12.0rc1, 2.12.0, 2.12.1, 2.13.0rc0, 2.13.0rc1, 2.13.0rc2, 2.13.0, 2.13.1, 2.14.0rc0, 2.14.0rc1, 2.14.0, 2.14.1, 2.15.0rc0, 2.15.0rc1, 2.15.0, 2.15.0.post1, 2.15.1, 2.16.0rc0, 2.16.1, 2.16.2, 2.17.0rc0, 2.17.0rc1, 2.17.0, 2.17.1, 2.18.0rc0, 2.18.0rc1, 2.18.0rc2, 2.18.0, 2.18.1, 2.19.0rc0, 2.19.0)
ERROR: No matching distribution found for tensorflow==2.11.0"
