Hello
Is it possible to put the tuner on a footswitch. Having two switches at the same time is very inconvenient for me.
Thank you very much
Not really at this point.
I believe there are some talks here in the forum suggesting to be able to trigger it with an external MIDI controller (for example some message from a MIDI footswitch). I don’t want to promise you anything, but would that be a valid solution for you?
