Finally got around to building out (and sharing) my first two original pedalboards, both of which are built around generators featuring tuned percussion. The first one is called “Merry Christmas, Mr. Sakamoto”, as the melodic sequence borrows from a Ryuichi Sakamoto tune. The second is called “Tuned Percussion Stutter & Glitch” and is a bit darker and more ambient.
I’m really loving the process of starting to build pedalboards for the Dwarf. This whole MOD ecosystem really has my imagination fired up and I can’t wait to build many more of these things over time, as my understanding evolves.
Hey @Frank_Paul! I’m happy to learn about this
Can’t you share the links here? If you can’t I will take a look on your account settings and allow you to share links.
QM - Thanks for noticing that! I tried initially just sequencing the melody itself, but without being able to fit in all of the inside harmonic lines (since they expanded the range to over an octave) it was a bit dull; thus the fills. Thanks again for your feedback! Cheers.
