Trying to build LiveCut LV2 plugin
So, i found this neat port of LiveCut to LV2
I prepared mod-plugin-builder docker for moddwarf
sucessfully compiled the plugin inside it. but, no luck to load it …
Jan 01 00:04:09 moddwarf mod-jackd[415]: lilv_lib_open(): error: Failed to open library /root/.lv2/LiveCut.lv2/LiveCut_dsp.so (/root/.lv2/LiveCut.lv2/LiveCut_dsp.so: cannot open shared object file: No such file or directory)
Jan 01 00:04:09 moddwarf mod-jackd[415]: can't get lilv instance
What should i look after to make it somehow to work ?
these are the contents of the .mk file
LIVECUT_LV2_VERSION = 1.0.0
LIVECUT_LV2_SITE = /home/dwarf/LiveCut-LV2
LIVECUT_LV2_SITE_METHOD = local
LIVECUT_LV2_BUNDLES = LiveCut.lv2
LIVECUT_LV2_TARGET_MAKE = $(TARGET_MAKE_ENV) $(TARGET_CONFIGURE_OPTS) $(MAKE)
NOOPT=true -C $(@D)
define LIVECUT_LV2_BUILD_CMDS
        $(LIVECUT_TARGET_MAKE)
endef
define LIVECUT_LV2_INSTALL_TARGET_CMDS
        cp -rL $(@D)/bin/*.lv2 $(TARGET_DIR)/usr/lib/lv2/
endef
$(eval $(generic-package))
