TinyGain Mono - MOD Devices
Robin Gareus
Tiny amplifier with output meter, mono version. A gain-stage with the range of +/-20dB and additional mute-control. The gain control is low-pass filtered at 20Hz to prevent zipper noise. The level display shows digital-peak (dBFS) of the output signal (rise-time: immediate, falloff: 15dB/sec).
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL2dhcmV1cy5vcmcvb3NzL2x2Mi90aW55Z2FpbiNtb25v
