Hi folks,
I was wondering:
Can a plugin draw a custom UI on the Dwarf LCD screen? For example, a looper might want to show where in the loop you are, or a compressor might want to draw a meter showing the amount of gain reduction.
Is there any way for plugins to auto-update, or do users have to go the store from time to time and click update manually?
Is there a way to see how much CPU and RAM each plugin is using, rather than just the system totals? For example, I was hoping to click on the CPU and RAM meters in the Constructor web UI and get a dialog with a breakdown of usage per plugin.
Thanks!
