If you look for the most versatile and balanced IR CAB the one from ML Sound Lab is the one:
It works with all types of amps and gains, for jazz, fender cleans, martshall crunch, hi gain sounds. It cost some money but it is worth every penny…
hoping for similar for bassists
If you like that, then you should check out MIKKO2. It’s probably the most versatile cab plugin out there and you can export the IR’s.
Hey thanks for your answer…
There’s no “Mikk02” Plugin to be found in the MOD Plugin Store, as I looked it up.
So, I assume you mean I should rather install it somewhere else and export then?
confused
thanks for clarification
