The infamous stuck - MOD Devices
Spencer Jackson
This effect samples the input, detects the primary waveform, and creates a drone of the note played when triggered. It is polyphonic and matches your tone. It may have pulsing/shimmering sounds on fuller chords.
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL3NzajcxLmdpdGh1Yi5pby9pbmZhbW91c1BsdWdpbnMvcGx1Z3MuaHRtbCNzdHVjaw==
Great plugin. Is it possible to make a stereo version of this plugin? I use a lot of parallel signal chains and I would like to activate the drone effect on both lines, but maintain the separation of the parallel chains so they can go to their respective sources.
