Hello,
Thank you so much for creating this plugin! I am using it to assign states of other hardware via MOD pedalboard snapshots.
Can you please investigate something?
mindi’s MIDI channel dropdown allows a range of 0-15, while all of my other midi-enabled hardware and software is configurable to channels 1-16, sometimes using 17 to mean all channels.
I have noticed that there is a discrepancy in how mindi behaves, for instance with Program Control messages, it sends messages on channel c+1, with c being the value shown in the dropdown, whereas control change messages are sent on channel c.
It seems that the displayed values should be 1-16 and for the behavior of all message types to conform to that.
Thanks again for developing this!
I cannot get it to work.
I want to set up the mod as an midi controler to change states of my Ampero 2 Stomp.
E.g. stomp changes between 3 scenes. cc25 value 1 is scene1, cc25 value2 scene2 and so on.
I set mindi to channel 0 and ampero to channel 1. but nothing happens. i use the same values from another midi controller and it works. where i the mistake?
Can you take screenshots of your board and of your settings for mindi?
thank you for your message. now it works. I did the same the other day and now it works. magic?
