Spencer Jackson
This shifter works well for monophonic sounds, allowing an easy control to change the shifting interval. Any interval between 2 octaves down and 3 octaves up is available. It also has controls that will slide to the nearest semitone after being adjusted, or to jump directly from semitone to semitone. It also provides a dry mix for chorus effects.
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL3NzajcxLmdpdGh1Yi5pby9pbmZhbW91c1BsdWdpbnMvcGx1Z3MuaHRtbCNld2hhbQ==
