Another Swell pedalboard for Ambience. This is primarily delay driven with the CAP pedal to add a little beat for interesting background effects. Make sure to use the volume pedal for the swell, or it's just overkill. Also, if you could tap in the beat that would put this over the top, but I don't think it's quite there yet. Also, I tried to reduce the feedback and time of the beat, but it sounds like the beat will keep playing in the background very subtly until the amp is muted.
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/pedalboards/57ae058a2564d4056cfdf829
