TAP Tubewarmth - MOD Devices
MOD Team
TAP TubeWarmth adds the character of vacuum tube amplification to your audio tracks by emulating the sonically desirable nonlinear characteristics of triodes. In addition, this plugin also supports emulating analog tape saturation. source: http://tap-plugins.sourceforge.net/ladspa/tubewarmth.html
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL21vZGRldmljZXMuY29tL3BsdWdpbnMvdGFwL3R1YmV3YXJtdGg=
I like to use this plugin because it adds some second and third harmonics to the signal like tubes and tape emulations do. Unfortunately a lot of these plugins are mono. Will there be a stereo plugin version available?
Greetings
mj_prod
