I can´t find a way to switch loops/tracks/recordings in the Audio File Player, when not connected to the web interface.
is that possible?
is that possible?
There’s a kind of workaround on this.
You can save a plugin preset for each track being played on the Audio File Player and then you can “Assign All” the presets to a pair of buttons or knob and this way scroll between all the files.
It’s not the optimal solution, but it works.
@Jon.
Thanks for the hint, I´ll try that now…
Just checking if there has been any update to the audio player to let you select tracks in a different way than using presets. As a workaround, it’s not ideal because presets are persistent across all uses of your device. So a pedalboard for one project will have it’s presets available to a pedalboard for some other project, and this means scrolling through way more presents than you would want for one project.
Unless there is some weird way to have presets not globally set?
Not yet anything on that.
