Switching from 128 to 256
As the use of neural modeling and IR reverb make us feel the limits of the CPU, it would be cool to have:
  • a plugin that could be used to switch from 128 to 256 frames and vice versa. Included in a pedalboard this would allow switching from the device without the Web GUI.
or
  • a switching option stored per pedalboard.
Possible ?
This has been discussed internally more than once and the implementation is a bit trickier than it seems.
That might be an option. We have the HW bypass plugin on the Duo and Duo X, which is kind of similar (configures a hardware setting)
@falkTX surely knows better than me :slight_smile:
@falkTX
Hi, any comment about this ?
Hi @falkTX
I’m back with this question. Having recently experienced cases on stage where the ADDA converter cascade causes high latency (particularly noticeable with acoustic instruments), I wanted to use a less CPU-intensive pedal board and switch from 256 to 128 frames. But this is unfortunately not possible without GUI. So, any option possible in the future?
