Switchbox changes don't follow on Dwarf
Description
When changing the output of the switchbox, it doesn’t follow up on the Dwarf
How to reproduce
  1. Put a Switchbox on your pedalboard and map the channel to a footswitch
  2. Change the output channel of the switchbox on the GUI 2
  3. now try to change the channel on the Dwarf
  4. notice how you actually go from channel 1 to 2 on the Dwarf, while you were already on 2 because you changed it to 2 in the GUI
Expected/suggested solution
fix the synchronisation that needs to happen when manipulating the switchbox in the GUI
Additional information
Win10
Version 97.0.4692.99 (Official Build) (64-bit)
Firmware V1.11.1.2644
Thanks for reporting this!
We will give it a check :wink:
