Hey Everyone,
this weekend i had another pretty loud gig in a small location. These two things are deadly for picking up the sound of any acoustic instrument (in my case the saxophone with a clip condenser mic).
But it’s these situations that give us ideas how we could deal with them better.
My Questions:
- is there a graphic eq (visible spectrum) that can be moved to stable and used with the mod ui? That would make eqing on stage awesome because i can see the frequencies i need to cut out.
- how do you rate the possibility of having two virtual pedalboards running in serial? By this i mean the primary pedalboard (atm i use one pedalboard per song or a small group of songs) and a secondary pedalboard which doesnt change and which is the input for the primary board. There i could make adjustments for the entire gig without editing every primary pedalboard. If not - using presets would be the solution - right?
Thanks for reading and your ideas!
