I got a Sonuus G2M to play the Fluid Synth Pad in the background with my bass side on the NS/Stick. Also using parallel compression which keeps the pure direct sound and blend it the compressed, more sustained note. Adds nice tone. Issue with Fluid Synth Pad... It causes CPU usage to sway from 30% to 100% causing digital clipping. You can hear it in this recording...
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com//pedalboards/57e8837afca7d905dacbbe55
