Hi, ![]()
I’m trying to get a midi controller pedal set up with Dwarf to control snapshots.
I’ve set up the midi snapshot channel on the Dwarf to 2 and the PedalBoard channel is set to off.
I’m connecting using the 3.5mm midi in to the controller midi out. I’m using a coupler to flip type to A-B.
In the controller software I’m sending PC 2 with a value 3 (to select the 3rd snapshot).
I have option in the controller software to test assignment for a specific PC (it can send 8 different values) and when doing this the snapshot on the dwarf changes. So I know the device can talk to the dwarf through the cable routing.
However when going into Preset mode on the controller the midi doesn’t seem to be taking effect.
I plugged in over usb and used the Midi Display plug-in to monitor incoming midi and I can verify midi is coming into the Dwarf as expected, PC 2, value 3, when the controller is in Preset mode.
What am I missing here? On one hand I think the controller software is buggy and on the other hand I don’t understand why snapshot is not changing when I can see the value is being correctly display in the Midi Display.
Note, MIDI is configured in the DWARF as Aggregate with loopback disabled.
Would appreciate any help.
Nelly
