What is the best way to go about having a flexible routing situation for switching between a mono and stereo rig. From my first playing around with the mod dwarf, it doesn’t sum automatically based on the number of outputs plugged in. Is there a plugin that works best for that that can easily covert my pedalboard from stereo to mono?
I think the switchbox 1-2 is actually the winner. I could put it at the end of the path to the R output and then switch it between the L and R outputs depending on the rig I’m running. That should work, right?
I guess yes
