Starless 18 with multiple controllers (use V1 version)
Overview
I have a version based on Starless 18 that adds the following:
  • Map HMI, CC, CV and MIDI at the same time to a parameter.
  • Directly map midi without using learn.
  • Lists, plugin presets and snapshots can be changed by MIDI. Including direct indexing.
  • Midi buttons/switches are now supported.
  • Tap Tempo from MIDI buttons/switches.
  • NRPNs, 14 bit CCs and Notes supported.
  • Midi Macros allow a single midi message to affect multiple parameters.
  • Advanced setting to invert the midi values.
Please look at the pdf file for more info:
Documentation is there in that release as a pdf file. Let me know if anything seems wonky!
Cool!
Hi @AndyCap can this be done also for device footswitches / knob?
EDIT: I read the documentation and I feel that it will be difficult ATM
I did have a brief look before and thought it looked like quite a bit needed changing.
The midi was quite simple to shoehorn in, although I am looking at making the whole midi side of mod-host a bit more efficient at the moment. I set Claude on it and it came up with some monstrosity so I’m looking at doing it by hand!
