Which plugin would be the equivalent of a spring reverb.
AFAIK currently there is not a good (or even a bad) lv2 spring reverb.
With a convolver you can use an impulse response for a decent spring sound, but no convolution lv2 plugins are on mod yet.
Isn´t this one based on a spring reverb:
Bumping this because I can’t make a new thread requesting a spring reverb plugin. Is an LV2 spring reverb plugin something that can be achieved? I have no idea how the plugins are created. Is a spring reverb plugin possible?
Regarding this part, I believe that now you are able to do it.
Well…an actual physical spring reverb not really for obvious reasons, but an emulation of it sure it is. I can’t at this moment check that, but I would suggest you take a look also at the beta plugins and search for something like that.
So do we have more spring reverbs in the collection ? The only one I could find is the dogood plugin, but is that it ?
Hey Azza, I discovered MOD’s Convolution Reverb plugin includes a bunch of DoGood Sound’s reverbs, including one of their spring reverbs. Sounded pretty nice to me.
Just a quick edit, I should have noted that within that same plugin there are several spring reverbs from Fried Silence, also very nice sounding.
You should find one or two in this lot ![]()
https://reasonstudios.com/blog/free-reverb-resources-where-to-find-impulse-responses/
https://www.waves.com/downloads/ir-convolution-reverb-library
