Spillover
About MOD Dwarf, there will be a sort of spillover while switching off reverb/delay effects? Or even better switching to another pedalboard?
I think that when loading a whole new pedalboard a spillover effect is impossible, as (if i’m not mistaken) all MOD devices reload the plugins.
on the other hand, a spillover effect should be very easy to achieve while remaining in the same pedalboard. You could for example put the reverbs or delays in only one of the outputs of a SwitchBox plugin.
This will be even easier to manage with snapshots.
Thanks! Since routing possibilities are almost limitless I think that would be doable. Nice!
