Hello, guys!
I am a frequent user of the looper. I don’t use too many pedalboards but all of them have a looper at the end of the pedal chain. I use to play live performances most of the times in duo, so the looper could be helpful and sometimes even spectacular. I use SooperLooper or Looperlative, depending on the needs of the pedalboard. However, something quite annoying happens almost every time I use SooperLooper: a glitch appears simultaneously with pressing the footswitch for loop recording. In very few cases this glitch does not appear but I could not find out what determines its appearance. For sure it’s not dust in the footswitch, I’m obsessed with keeping my devices crystal clean
Unfortunately the glitch is recorded with the loop and sounds very disturbing when the loop is played. Has anyone experienced something similar…?
I think that’s a limitation of this looper. There are clicks in every recording starts.
Now I use Looperlative that doesn’t have this issue.
Sometimes it is more convenient to use SooperLooper, just record and play a single loop at a time to improvise over. But I guess I will replace it with Looperlative in all my pedalboards. The glitch is too much annoying.
