Sooperlooper + Multi Button CV
Hi there,
any Idea how to add reset to the Multi Button?
Best Regards,
Lukasz
Hi @Lukasz,
As the Reset function isn’t assignable to CV, the key is using MIDI through the Infamous Mindi plugin.
Enable Virtual MIDI Loopback and connect the Mindi to this output.
Assign the long press CV port to the Mindi value parameter.
Assign SooperLooper Reset to MIDI and do the long press.
Thanks, I will try it!
