Description
when a parameter is mapped to a button (in “momentary ON” mode) on the Duo X, switching to the page containing that button shows it as ON (i.e. it has a dark background on the Duo X display), even though it is actually OFF. then, the button does operate properly, and leaves it showing as OFF (light background). to put it another way: the display state does not match the actual state of the mapped parameter immediately upon switching to the page.
How to reproduce
- make a new pedalboard
- map the ON/OFF parameter of the gain plugin to a button, in “momentary ON” mode.
- map the gain setting to a knob on another page
- on the Duo X, switch between the two pages
- note that, when arriving on the page containing the ON/OFF mapping, the Duo X display initially shows the parameter as ON (dark background), even though it is actually OFF – then the button operates normally and the display is correct after pushing the button (the button light is always correct… only the LCD display panel is incorrect)
Expected/suggested solution
make the display status always match the actual parameter status
Additional information
Duo X:
- release: V1.11.2
Computer:
- Operating system: macOS Big Sur
- System version: 11.6.3
