Slew rate limiter
Anyone have any tips for making longer ‘fall time’ on the Slew Rate Limiter?
I essentially use this for envelope following and would like a longer envelope release - I find the 1sec fall time too quick.
Hello @Kevin ,
thanks for the plugin request.
I looked quickly in the documentation pdf of the Tal-U-No-LX I have installed on my mac.
On page 12 it says as following:
The ADSR has following specification:
Attack time (1ms - 3 sec), Decay Time (2ms - 12 sec), Sustain level (0 - 100%), Release time (2ms - 12 sec).
Might these parameter values for attack( rise) and decay (fall) time seem more appropriate?
I’ve just put a few of the slew rate limiters in serial and use the last cv output.
edit: this is the pedalboad im using it this way
@mj_prod @spunktsch Thanks for the response(s) - will give them a go!
Thanks @Kevin ,
and @spunktsch Sebastian’s pedalboard is the perfect example the mod platform is capable of:
to go beyond limitations while inventing something unique but versatile and useful born out of necessity.
