Hi, playing with the MOD received a month ago is a pleasure, and i’m starting to build useful pedalboards for guitar.
In the process, i’m missing a simple “mono signal to stereo signal plugin with a balance control.”
I’m not ready yet to go into the process of installing the toolchain to port an existing plugin, so 'im asking here if you plan of releasing such a plugin, or if someone could do it ?
I found this plugin which can do the job perfectly : https://github.com/x42/balance.lv2
BTW, i haven’t found any suitable plugin in the existing list, and was only able to do what I need duplicating the signal and using 4xGain plugins to make the stereo balance outputs.
Yup, I’d like this too - I’ve managed to get the Wider plugin to feed a sidechain via CC control, but a proper pan, with the two extremes as up/down on my CC pedal would be wonderful.
ok the first try led to a usable result, but the balance is not working exactly a “Pan” for each incoming signal. I can mostly balance the volume of each input which is either hard panned left/right when using 1st and 4th inputs, or on both sides when feeding 1st/2nd input and 3rd/4th input with the two signals.
I’ll publish my pedalboard so you can have a try and hopefully better understand my description
Still, a kind a “4 channel Mixer with pan” would be the best option for what I want to achieve.
While one could build it simply using a couple of “gain” plugins, a small dedicated mixer would indeed be nice to have on the MOD. When you say 4 channel mixer: do you mean 2 stereo pairs or 4 stereo pairs (8 total inputs)?
indeed for the first try I used 4 gain plugins, worked perfectly as expected, but when adjusting moving 4 knobs is really not user friendly.
Reffering to the linked information, I’m more interested in a “Balance” control but with a MONO input signal and a STEREO output signal (the mono input si duplicated to both output channel, and then the balance is applied)
