Hi folks,
I’m hoping someone here would be able to let me know how to set the sample rate of the MDX to 44.1kHz so I can connect the Akai Force to it, as currently an error pops up on the Force saying the MDX may not support this rate. Furthermore, how would I (if it’s even technically possible) be able the MDX to see all 32 channels over USB? I already have 2 showing up, and can connect via USB from a Maschine+ so USB is available at least, but a fair couple of channels short of the 32 I’d like (16 stereo channels or 32 mono).
Many thanks for reading so far.
You cannot change this sample rate and quite intentionally so.
There are a few plugins made for MOD that assume 48khz as sample rate, changing this will break them.
For the USB 32 channels, not sure what you mean. We do not officially support anything like this.
Thank you. Guess I’ll go with a Behringer mixer then. I was trying to do something non-standard anyway.
