setBfree Whirl Speaker - Extended Version - MOD Devices
Robin Gareus
A rotating loudspeaker emulator designed to imitate the sound and properties of the sound modification device that brought world-wide fame to the name of Don Leslie
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL2dhcmV1cy5vcmcvb3NzL2x2Mi9iX3doaXJsI2V4dGVuZGVk
Hi, I am looking for an elaborate simulation of the famous Leslie rotary. Normally, you can switch between low and high speed rotating.
I would like to be able to control the rotating speed on a continual scale by an expression pedal. Is this one capable of doing this?
In case Speed Slow or Speed Fast can be controlled by the expression pedal, would this do the job? (As I am awaiting delivery of my Dwarf I cannot explore this yet.)
