Hi, there’s a way to send midi program changes from the Mod Dwarf to other pedals? I would like to buy the Morningstar ML5 and use it together with the Dwarf as a switcher to be able to control analog pedals. This implies that I would have to send MIDI Program Changes from the Dwarf to the ML5 in order to switch from one pedal to the other. Are there any alternatives or workarounds to make a similar setup? Thanks for the help!
You can use mindi from the beta plugins to generate midi messages and output it on the midi out.
Note that the plugin generates the message when activated. So when a pedalboard is loaded every active mindi sends its message.
