Saving Local Snapshots not working?
I propably missed something but when I save a Snapshot from the Dwarf Device it is gone the next time I start it up again.
Seems strange since it is a basic function. Any Ideas?
I believe you also have to save the pedalboard after saving the snapshot. Could you try that and see if it works?
That’ll be most likely it; had the same problem when I started with the dwarf. I believe I’ve seen several people struggling with this here (example), so maybe this would be a good candidate for UX improvement.
I agree, saving snapshots should save the pedalboard or at least notify that can the user should do it
Until the behavior is changed, I find it helpful to think of a snapshot as a child of a pedalboard, and therefore you need to save the parent pedalboard to save the child snapshots. I do agree that this is not exactly intuitive.
Ah reading the other thread I realise that I have to save the Snapshot and than save the Padleboard?
Ok, that is strange and feels akward from UX point of view…
In my case, when I use either of the side buttons on my Duo X to save a snapshot it’s not clear whether anything is actually happening. I also cannot find where snapshots are stored on the device, nor do I understand how to access them when disconnected from the web GUI. Can any of you explain this please?
I mean, what would be the point in saving snapshots if they cannot be accessed on the device itself and assigned to either the device’s own switches or an external controller?
I don’t own a Duo X so I can’t help you with your device specific problems but have you read these paragraphs ?
https://wiki.mod.audio/wiki/MOD_Web_GUI_User_Guide#Saving_.2F_loading_pedalboard_snapshots
https://wiki.mod.audio/wiki/Duo_X_User_Guide#Instant_Snapshots_2
Also, Device Settings - MOD Wiki to set the Program Change channel the Duo X is listening for.
