SampleV1, SFZ or another option?
Hi!
I love using samples as keys but using SampleV1 doesn’t work for me because making smooth loop points is nearly impossible, also because of the lack of visual feedback.
I have AIFF-C files with built in loop points so maybe it can read those off the bat?
I’ve never used SFZ instruments so this might be easier than thought but it might not…
Also no clue how to import and properly use them within my mod duo + I’m pretty sure basic ADSR isn’t possible within the plugin right?
Are there any other easy ways to use, edit and play samples on the Mod Duo?
You should do it on the File Manager. You can see it in the bottom left corner of the WebGUI (next to where you go to access the Plugin Store). There you upload the files to the correct folder and then the plugin will find them.
Edit not really, only process. Play, you have Exampler, but is not that advanced. You can also use the Audio File Player if that fits for your needs.
well yes but SFZ files would first have to be made and probably cannot be edited in the mod gui
