rkr Vocoder - MOD Devices
Rakarrack Team
32 band vocoder. This type of effect is well known for creating robot-like voices in popular music. The input is divided into frequency bands and each band's volume is controlled by an auxiliary input's frequency curve such that the output signal is filtered to sound like the aux signal.
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL3Jha2FycmFjay5zb3VyY2Vmb3JnZS5uZXQvZWZmZWN0cy5odG1sI1ZvY29kZXI=
How do I set it up to play with?
Can you make an example pedalboard?
The documentation of the original piece of software may help.
https://rakarrack.sourceforge.net/effects.html#Vocoder
Hey
Great info. Thank you. Interesting reading
I’m trying to use the effect in a mod dwarf with a usb keyboard
Im wondering what and how to connect and use to get that sweet vocoder sound out. The plug-in has three inputs and two outputs
