Rakarrack Team
An extremely-configurable delay that allows up to 127 taps. Individual tap timing can be customized and loaded through text files. You can also have a custom filter on each tap. Several example files included.
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL3Jha2FycmFjay5zb3VyY2Vmb3JnZS5uZXQvZWZmZWN0cy5odG1sI0VjaG90cm9u
