Rename pedalboards
Hi all, I’m a new user trying to find if is it possible to RENAME a pedalboard (of course it is possible to “load”, “save as” and “delete” the previous one but I guess it’s not the same - thinking at banks for example). Does such rename functionality exists and I didn’t find maybe? If not I think this could be an interesting feature request.
The backend appears to have a rename option https://github.com/moddevices/mod-ui/blob/c926055bcc05e47cc50f86ee56176871e8ac45cd/mod/webserver.py#L1321
But I don’t remember to find a rename option on frontend. I use save as and delete too
@dijio I usually save the pedalboard with the new name and delete the old one. There is no option for renaming as far as I know.
Yep; saving as and deleting is an acceptable workaround in most cases, but you lose bank assign, and when you have to do it on many pedalboards (i’m changing naming convention) is a bit annoying.
Thanks for answers :pray:
that’s a good info, maybe the feature request will be accepted easily :slight_smile:
